[4]
Electronic Preset Gauge
[3]
[10] Like what you see?
ddickey
H-M Supporter - Gold Member
Apr 21, 2016
1,920
Worthwhile to use? Found one in my toolbox.
kd4gij
Feb 7, 2011
4,698
If you have or plan to have a CNC mill that will come in handy.
Boswell
Hobby Machinist since 2010
H-M Platinum Supporter ($50)
Feb 27, 2014
743
Use one like all the time to zet my Z-Axis Zero. While I am using a CNC, I don't see why it is not just as useful to set the Z-Axis zero point for manual operations as well.
ddickey
Apr 21, 2016
1,920
Yeah, I'll give it a try.
So you touch off with your tool on to the gauge. When the light goes off you look the quill. Then you know you're exactly two inches for the work. Moove the knee up accordingly.?
P. Waller
Mar 10, 2018
913
A tool setter, use it since you already have it, think of if it as a contact edge finder for the Z axis, it is no better or worse then any other method, if you use a good deal of solid carbide mill tooling it will help.
Boswell
Feb 27, 2014
743
You got it.
P. Waller
Mar 10, 2018
913
Many home shop machinists have never used a machine that has no handles or mechanical hand wheels connected to leadscrews and have never experienced the joy of running a tool into the part with a jog button (-:
Boswell
Feb 27, 2014
743
I hate to admit it but I am on my 2nd one of these after "Jogging" the wrong direction after touching off. It has quite a lot of spring based movement to allow for that type of mistake but everything has a limit :apologize:.
hman
Feb 17, 2013
1,945
Very true. And even with handwheels, there's the possibility of chipping or otherwise damaging the cutting edges of a end mill (especially carbide) - or affecting the surface of the workpiece - when touching off. Here's an article by Rick Sparber (a forum member) illustrating a safe alternative way to get a Z reference:
http://rick.sparber.org/sawsem.pdf
Enjoy!
[6]
[5] [7]
