New to me Enco 9 x 42 step pulley mill. The head will tilt and nod just fine. The turret will rotate just fine. The head will not move in or out. I have the 2 lock nuts loose but the lever for the pinion shaft is not turning. I removed the pinion shaft and oiled it up, sprayed the dovetails with penetrating oil and then some way oil. Any suggestions?
