• Over 10 years ago, (September 10, 2010), Nelson Timken, our founder, had a dream of a friendly machinist site, where people could learn the hobby of machining. We want to wish everyone a healthy, happy New Year, full of joy and success. God bless you, and thank you for supporting The Hobby-Machinist.
Enco RF-30 One Shot Lube System
TomS
May 20, 2013
1,902
On another forum thread a member asked me to post pictures of my RF-30 one shot lube system. I thought it best that the pictures and responses reside in this manufacturer specific forum. So here goes.
This is a Bijur pump that I bought used off of eBay. It has worked flawlessly for more than five years. It didn't have a plunger handle so I made one.
This is the distribution manifold I made. I used Push-to-Connect fittings. On my CNC mill conversion I used 1/8" NPT x 1/4" hose compression fittings. Either will work.
The system is plumbed using 1/4" OD Tygon tubing. The lube system feeds the X and Y dovetails, three axis handwheel support brackets, and the X and Y axis feed screw nuts.
A close up shot of one side of the Y axis lube inlet.
craptain
Sep 21, 2017
94
All I can say is WOW.
That's an impressive system.
Sent from my SM-G930T using Tapatalk
TerryH
I have no clue what I'm doing...
May 8, 2018
336
Very impressive Tom! Nice work.
TomS
May 20, 2013
1,902
Thanks for the comments guys. It's one of those mods that has paid dividends in that the only way to lube the X and Y feed screw nuts is to stand on your head and manipulate a oil can in an awkward position to get oil in there. This mod makes it easy.
stioc
Feb 22, 2017
589
Thanks for posting the pics Tom. I must admit I didn't even know those needed to be lubed periodically. I mean I clean and squirt a couple of drops in the dove tails every now and again because I thought that made sense but I recall when I got my RF30 I didn't find any reference in the manual for periodically oiling any parts of the machine.
Also, when you say X and Y feed screws- same thing as the lead screws right?
mattthemuppet2
H-M Supporter - Gold Member
Sep 28, 2013
2,580
lovely work. Quick Q - did you use flow metering whatsits and/ or ball check valves? I have a similar oiler on my 6x26 mill and it doesn't have check valves, so the oil drains out of some of the lines back into the reservoir, so I have to pump it several times to get those lines filled while the other lines pump too much oil. Be neat to stop that happening but I don't have a clue where to look!
Buffalo21
Feb 24, 2018
878
I put a one-shot oiler, on the 1940 Bridgeport based Franken-Mill and the Atlas/Clausing (Johansson) milling machine based Franken-Drill. I made all of the line orifices and be set the flow to each port.
TomS
May 20, 2013
1,902
Yes, feed screw or lead screw, they are the same.
TomS
May 20, 2013
1,902
I installed a check valve at the inlet to the distribution manifold. Take a look at the first picture. At the top of the manifold you will see a pipe nipple and a brass fitting on top. That is the check valve.
AdBlock Detected
I've Disabled AdBlock
