- Oct 5, 2010
- 1,044
The key word you are looking for is "32mm hardware."
This is a hardware standard used for making low end cheap furniture in Europe.
It caught on in America because we foolishly believe that all things Euro are classy, and because it is moronically simply to install.
It does disappear from view when the door is closed, but requires a fairly thick and wide style for installation cause smaller doors to appear ungainly.
You can get it by the crate almost anywhere that sells hardware to the pros, or pay 5x price from a retailer like Rockwell.
Sorry if I offended, it was not my intent.Having been in the custom cabinet business for over 20 years I have never seen a fully self closing "euro style hinge" Your best bet is to use a small door closer in conjunction with the hinges. Most of the hinges have a spring that provides a little detent that holds the door open and closed, you might need to remove it if using with a closer.
Yes the 32mm system used on cheap low end cabinets but it is also used on the highest end custom cabinet work as well. There is a wide range of quality available.
Not sure what you mean by "moronically simply" to install. The mounting holes have to be bored at precise dimension and location. Also the hinges don't require any "style" (stile), they can be installed in a simple slab door only ⅝" (16mm) thick.
