I've had several of the smaller strap wrenches fail with the rubber splitting and the inside reinforcement threads then failing. They're made by Pittsburg. Anyone had this sort of problem? I haven't used them much except for opening bottles or large glue caps that got stuck. The larger strap wrenches I use for removing stuck chucks on the lathe along with a hex bar. The larger strap wrenches look like they too may eventually go bad.
Maybe the brand is bad?
