- Nov 15, 2016
- 943
Hi, I think you might have misinterpreted that post. I was quoting you. With a bushed little end in a connecting rod you fit a new bush, make sure that if there is an oilway that it is correctly aliened or as with many splash lubrication pumps,(that includes I.C.E.), that a new hole is drilled and then you hone the bush to fit the gudgeon pin. Getting the little and big ends in the same plane is vital as otherwise all sorts of stresses get set up and you get accelerated wear on both bearing, the rings, the piston, in all just not good. The problem here is that the unsupported area under the bush is in exactly the place subject to the most force and that area left unsupported will distort. How long it takes is anyone's guess. Probably last a few years if a new bush was fitted and the lubrication sorted. Horses for courses. Belzona Epoxy https://www.belzona.com/en/products/purpose/metal-repair.aspx would have something for this application but the best would be ream then hone it true and round and fit an oversize bush.See the picture of the little end of the rod. The problem isn't sizing the bushing, it's the slot worn in the rods small end.
