- Jan 5, 2014
- 959
I have a design question. I need to make a 1.5" diameter, 0.25" thick disk that will friction fit concentrically onto a 0.25" diameter shaft. It needs to be tight enough to not move under light force but reusable (taking off, putting on) maybe a few dozen times a year. I tried just "right sizing" the hole in the disk but it got loose over time.
Is there a book or article that shows how to design the plastic spring legs that are sometimes cut into objects like this? Usually, they are sort of "L" shaped legs that are cut into the plastic and arranged every 90 or 120 degrees around the hole diameter. I'm not sure what the technique is called so I can't seem to find anything.
The project is a thread spool holder that the sewing machine manufacturer would like $180 for. I would like to keep that $ and build it from scraps I have (and maybe buy a different tool of some sort). I'll send a picture when I get a minute later today.
Thanks
Thanks
