- Oct 14, 2014
- 1,976
I just spent a month learning to design in Fusion 360. Great product for design.
I just skimmed through the CAM section but did not see a capability I will really need. The ability goes by different names. At the gcode level its G41 G42 cutter comp, or it can be called tool wear, or tool offsets. This allows you to change tool diameters at the machine to make fine adjustments in critical part dimensions.
Does Fusion do this? Could you point me to the right spot to learn more about it?
