• June Project of the Month (Click "x" at right to dismiss)
[4]
Fusion 360 Rule#1
[3]
[10] Like what you see?
jwmelvin
Active Member
Active Member
Jan 11, 2018
93
Likes
67
10
#31
I drew several bodies and then converted them to components (not following rule #1.) Now that they are converted and are part of an assembly, I have lost any ability to see the timeline or the underlying sketches. Is this normal? Would this be different if I created the component first and then added the sketches?
Yup, now you see why they call it "rule #1." As MikeWi pointed out, the sketches are still there but the design becomes very confusing when you do it the way you did rather than create components before creating geometry.
rwm
H-M Supporter-Premium Member
Mar 25, 2013
1,270
Likes
1,406
20
#32
I see the sketches now. They are only visible under "sketches" and not under each component. Thanks again for the clarification.
Not sure if I will build it, but I was trying to envision a double fat tire bicycle!
Sure would look cool.
Robert
Technical Ted
H-M Supporter - Premium Member
Nov 5, 2016
433
Likes
463
20
#33
Try left clicking on the sketch and drag it into the component. Sometimes it will let you do this.
Good luck,
Ted
[6]
[5] [7]
