Re: G0704 CNC'ing
Well, the 48v 600w power supply I ordered showed up yesterday.
Pulled out the 24, and stuffed this one in loose.
I got almost double the rapids on my X&Y! Z sadly has made no change. Stuck at about 35 in/min before the motor stalls. Mind you, at that speed, I'm pretty sure I could climb on top of it and it'd still move!
I'm going to pull the enclosure apart (yes, the one above) and redo it. I got a good deal on a pair of 12*12*6 (vs the 4 I currently have). Attached them to each other with conduit. I'll put the 120 A/C stuff in one, and the controllers etc in the other. Then just run a couple of DC lines from one cabinet to the other. It's just getting too crowded, and now I'm looking at adding more (4th axis, C6 spindle control, C3 speed feedback, touch probe interface.... etc!) so it was just nuts.
