- Dec 1, 2010
- 1,172
Hello Guys
I posted a few months back about styrofoam isulation on my wooden garage door.Well guess what? I did all the seals, and just never got back around to it.
I did have another project in the house to do, and need to rent a van to haul some drywall and wood home. So I picked up a couple of sheets of 1 inch styrofoam while I was there.I have a few questions for those that have done this before.
The styrofoam is that blue coloured stuff with a foil cover on one side. Im not certain if the foil goes against the garage door, or faces inside the garage? The nex question is about cutting this stuff. Ive never worked with it before, so have no clue. I figured on cutting it with a exacto knife, but not sure if there are better ways to go about it? Being the door is wood, Im going to need to cut around all those hinges.
I also have seen another product over at home depot. It comes in several different size rolls, and is supposed to be a insulation / heat barrier of sorts. It is available in rolls as mentioned. It appears to be about 1/8 inch thick shinney foil type stuff.
I was thinking of putting this over top of the styrofoam, facing inside the garage, what do you guys think?
I was thinking of glueing it on to the styrofoam panels before installing them, hoping it would help keeping the heat in the shop in winter, and help control heat coming in the shop in summer.
Any Home improvment guys around here?
Thanks
Paul
Thanks
Paul
