I do not do a lot of spiral work, just occasionally, also differential indexing, just when needed for prime number indexing such as 127 for metric transposing gears, yes, I do have a lift, I used a barn door track and a HF electric hoist; I used to lift such things as the dividing head and lathe chucks by hand, back troubles no longer allow suchlike. The weight at the end of the table is just one of those things that are a necessary thing, in some cases, such as when the dividing head is geared to the table screw, other times it may be placed anywhere on the table that is convenient, like using a vise, it can be located anywhere. Setting up for spirals is quite easy and can be done quickly, although it might take some extra work to set up on a non Brown & Sharpe machine, which has a couple of drilled and tapped holes on the end of the table to accomodate change gear brackets. The information on spiral setup is contained in B&S book "Practical Treatise on Milling and Milling Machines" find a copy online or perhaps E Bay, it is a gold mine of info, including spiral work and indexing and lots more.
