• WTH HAPPENED TO H-M?
    After accidentally deleting a folder, we asked our web host for a backup. As nearly as we can figure, the 1/23 backup did not contain any attachments (over 250000 or avatars for our members). We then asked them for a backup to January 1, 2020, and THAT backup had no attachments or avatars, etc. Their backups were incomplete apparently, and overwrote our files with empty attachment files. We are very sorry for this. We are doing everything and anything we can to right this. HM
Grinder accident
SE18
Feb 26, 2012
758
I was using my angle grinder to remove a weld. I was wearing wrap-around goggles from Harbor Freight that I thought would prevent sparks from reaching inside (the wrap arounds touch skin on all sides). But a spark somehow got inside, landing on my new expensive glasses made of plastic and melted a spot on the plastic. I'm going to see if the spot can be buffed out.
Bob Korves
H-M Platinum Supporter
Jul 2, 2014
7,203
Unfortunately, I doubt if the spot can be dressed out, actually, I think you will find them not interested in doing it even if it is possible. They will try to sell you a new lens. Another good reason (beyond the desire to keep on seeing) to wear double eye protection with tools like angle grinders, cut off tools, Dremel type tools, bench grinders, snag grinders, and similar tools.
4ssss
Apr 25, 2017
676
There are certain things from HF that you don't buy, and that is anything that you think you'll need for more than 1 time before throwing away. I'm glad you're OK, but I hope you learned something.
MikeInOr
Jan 1, 2018
340
Not only would they have to buff out the melted spot but they would also have to strip and reapply any coating you paid to put on the lens. Then that spot on the lense and around it isn't going to be focused properly for your prescription leaving a fuzzy spot in your vision. I think you are best off getting a replacement lens.
I recently broke an arm off my expensive glasses when I hit myself in the head with a 2x4. Local optic shop wanted $200 to replace the broken arm on the glasses. I found the manufacture and model number of the frames on the broken arm and ordered an entirely new identical frame from EZContacts for $70 with free shipping. A bit of youtubing gives me confidence that I can swap the lenses to the new frames myself. I know I paid over $200 for the frames from the local optical store when I bought them.
So how did a spark get around your eye protection onto your everyday glasses? You aren't supposed to take a shower in the sparks when you are grinding! :cool:
Good job on using both safety glasses and your every day glasses. Eye surgery and the possible loss of sight makes having to buy a new lens seem pretty inconsequential!
Tozguy
Feb 15, 2013
2,062
How new are they? Sometimes there is a chance that they might replace the lens at a discount.
Z2V
May 10, 2017
799
It’s good that you had the goggles on or that spark might have got past your glasses and into your eye.
Oh, MikeInOR, don’t bother telling us why you hit yourself in the head with a 2x4
Z2V
May 10, 2017
799
^^^ ACHiPro, I have that shield as well. Best I’ve ever used for the price, very well made.
C
cg285
Forum Guest
Register Today
never gets on my glasses. always goes straight for the eyeball
MikeInOr
Jan 1, 2018
340
Because it was there!!!! :bipolar: DUH!!!!
Working too late assembling a frame to lift my new to me lathe out of my trailer... one of the braces slipped while I was trying to get the screw gun on it... had just enough momentum to knock some sense into me and break my glasses. I took a shower and went to bed after that instead of finishing up and trying to move the lathe when I was too tired.
Dredb
Jan 6, 2018
94
Same thing happened to me a few years ago, a spark found it's way through a very small ventilation hole in the (soft) frame of the goggles and raised a blister on the edge of my eyelid. Could have been worse!
Personal protective equipment may limit the severity of an injury but it's best not to make assumptions, think about what you are doing and if further precautions may be needed.
middle.road
Actively Learning...
Apr 28, 2014
2,208
I had my 'close up' glasses on a granny strap when I went and used the angle grinder. Forgot they were around my neck.
I've even got a special hook on the big tool box to hang them so that they wouldn't get dinged up. *Memory Loss*
Ruined them.
Luckily there's a discount eyeglass shop here in Knoxville. Under $60 for a new pair.
The ones I ruined were $230.
westerner
If you are gonna be stupid, ya gotta be TOUGH!
Mar 29, 2017
338
Many in this field consider a mini-grinder THE single most dangerous tool in the shop. I will wear that reminder forever on my wrist. Wire wheel, insufficient attention. Wheel caught an edge, jumped out of my SINGLE hand holding the grinder. At full speed, the wheel caught my other wrist and launched the grinder across the shop. The wound was raggedly spectacular. About 9 things done wrong. Cheap lesson, never to be forgotten
whitmore
Mar 3, 2017
451
I was using my angle grinder to remove a weld. I was wearing wrap-around goggles ... But a spark somehow got inside.
My hand grinders turn the same way (counterclockwise looking into the working end) as a drill. But,
when you need to watch what you're grinding, and apply pressure while holding the grinder
in your right hand, that sends sparks right toward my face. Other than converting to left-hand
work, or doing an awkward backhander grip, there's just no way to get around having a sparks
versus faceshield exercise.
So, does anyone make a hand grinder that is ergonomically correct for right-handed
users? With clockwise rotation? A memorable feature is that the wheel would
be retained with a lefthand fastener.
pstemari
H-M Supporter - Gold Member
May 18, 2015
495
Not sure I follow that. The guard should keep sparks away from you.
If you're holding the grinder body in your right hand and the side handle in your left, using the edge away from you, the sparks should be going to the side, not back at you.
If the body of the grinder is at 6 o'clock, the side handle is at 9 o'clock, the guard is going from maybe 4 o'clock to 10 o'clock, and the cutting action is around 1 to 2 o'clock.
Sent from my Pixel XL using Tapatalk
Tozguy
Feb 15, 2013
2,062
My goggles have indirect vents and have done the job for a good while now. As you can see the grit gets everywhere, even in the joint between lens and frame.
When I am grinding I am focused on the job and not so much on which direction the sparks are flying. I prefer googles to a full face mask most of the time. I am still looking for better goggles that are idiot proof. Price is no object.
SE18
Feb 26, 2012
758
I have one more experience to share while on topic of grinders. I was doing some grinding (I forget it it was bench or angle grinder it happened so long ago) on a cold winter nite in my garage wearing a thick shirt. Lots of sparks. Suddenly, I started to feel nice and warm and comfortable. Then a bit hot. I looked down and my shirt was on fire. Burned a nice 5" diameter hole, no injury. I still have the evidence.
Silverbullet
May 4, 2015
3,552
It seems no what I've ever tried the sparks , slag, all of it bounces around till it gets in . My three hundred dollar welding Helmut YUPP you should see my glasses and I buy glass lens at least some only leave tiny spots. Even grinding I use a full face shield and goggles. They are sly invaders , take a look at my socks and feet. I've even been on fire from the crap. I just thank god I've never had a bad one in my eyes.
SE18
Feb 26, 2012
758
Silver bullet: I think the fluid in the eye would extinguish a spark pretty quick, but I'm no doctor. I thought I was the only one with spark problems but I see there are others. I bought my glasses a month ago and the spot is in left lens. My right eye has floaters (a problem some of you over 60 might experience), so I'm used to seeing spots. I'll just soldier on with the glasses and supplement full face shield with goggles. Problem is, it's uncomfortable and harder to see with multiple layers of eye protection. One operation where I do use multiple protection is with my table saw. I had some nasty kickbacks with it in the past.
KBeitz
Apr 17, 2018
505
I grind and cut so much that I keep a super magnet around to
pull metal out of my eye if needed. it works...
Winegrower
Jul 29, 2014
534
We keep a full face shield near the grinder at the Railroad Museum. It is so easy to just take it off the hook and slip over your head...since I wear glasses, the goggles are just too annoying. Plus, the shield protects the rest of your face as well.
jocat54
Dec 25, 2011
540
If your glasses aren't too old they might replace them. I was weed eating a couple of weeks ago and sweating lie a stuck pig and could hardly see through my glasses, so took them off too finish. Laid them down on a table outside my shop---when I finished came back to get them and see one of my dogs chewing on something---yep my glasses or what was left of them.
I called the place that I bought them from and they said if they were under a year old bring them in and they would replace them (free for any reason)). They were just about 2 weeks under a year. I was very pleasantly surprised.
solo
Mar 23, 2013
69
We use these at work. I plan on buying one for home. Very nice! Uvex bionic face shield. 37.00 and change
Z2V
May 10, 2017
799
I have one also, best face shield I have ever used!
aliva
Feb 28, 2012
439
It's possible the scratch can be removed or lessened in severity without changing the optics. If it can't ,keep those glasses for shop use and buy a new pair.
