Grizzly 12x37 face plate made
Ryan383
Newbie
Jul 18, 2017
13
I couldn't find a faceplate for my old 12x37 anywhere so figured I would start making one. My manual said the spindle was 2 1/2 -8 thread but the major diam measured 2.356" so I decided to just match that with the female threads.
kvt
Oct 21, 2014
2,083
Looks nice.
rock_breaker
H-M Platinum Supporter ($50)
Dec 31, 2010
690
Nice looking face plate! No doubt it wouldn't be here unless the project was successful, any comment on thread engagement and run out?
Have good day
Ray
Dabbler
Administrator
Staff member
Oct 11, 2016
1,043
I have your exact lathe sold by Busy bee (purchased in '81). So hold on you your hat. The spindle is actually a 62 mm X 8 TPI!!! Yes it is! Someone here on the forum (I'm sorry I can't remember who) alerted me to this fact. I hope this helps!!!
I have a friend with the same lathe and he's made a very close mock up of his spindle to work as a go/nogo gauge... He's build several (perhaps 4 or 5) backing plates for it, and they are near perfect!
benmychree
John York
Jun 7, 2013
3,827
I have seen that even sloppy threads on chuck backing plates will still center up accurately, having said that, I personally make a thread gage for every lathe that I've had over the years, and also try to fit the unthreaded portion of the backplate for a close fit on the spindle.
Ryan383
Newbie
Jul 18, 2017
13
Yeah I just measured and went for it, couldn't have asked for better thread engagement. No tightness and almost zero slop. The bore that it registers on is a little tight, but better that than loose
Ryan383
Newbie
Jul 18, 2017
13
I had a hard time deciding how to hold it so I could bore/thread it. A rotary table on the mill would have been nice but I don't own one. So I plunged the bit in between each gusset and turned it by hand so I had 3 surfaces concentric to the bore, so I could flip and run in the 3 jaw.
pdentrem
Jan 28, 2011
2,137
What size weight are you using? I have not found a face plate for my lathe yet and looks like never will.
sixball
Active Member
Jan 10, 2019
35
Good work. Your lathe is also identical to my 1985 Shenwai SW 900B.
