So today was fairly busy and I didn't get to tinker with my lathe until this evening. I decided to strip her down naked and inspect anything and everything. First I took some readings on my spindle though. On the outside end I have right about a half-thou of runout, same exact results on the chuck end. I didn't take any readings in between, but will soon.
Taking the carriage off was was a bit of a task, but nothing out of the realm of possibility.
I assumed that because the bed is ground to precise dimensions and finish I would assume that anything else sliding on it would share the same properties. Maybe this is the wrong thought process, because when I flipped the carriage over to inspect the finish I was very surprised...
It appears as though they took the "out of sight, out of mind" approach to this particular process. In short, I was not a very happy chappy when I saw this. I know what a properly piece of scraped metal is supposed to look like, this looks like a horribly cast hunk of metal that was ground the least amount humanly possible and then had a hammer taken to it in a fit of lathe-making rage. Perhaps I have no idea what Im talking about, but It appears as though this is not good for precision machine-work.
Out of curiosity I decided to cover everything with dykem to see where it was actually contacting. I put it back together, ran it up and down the bed a few dozen times and then pulled it off....
Im not sure If I should be PO'd about these results or not...But I am. While this isn't something that could have changed in the last few weeks to cause a deterioration in machine work finish, I still believe it's a problem. I took some 1000 grit sand paper wrapped around my buddies small precision ground block and went up and down the surfaces a few time to knock down the high spots a bit. I put everything back together and cut some aluminum, the surface finish was better. But still not back to it's original glory.
Im to the point where I feel like putting the dang thing up for sale, informing the buyer of it's shortcoming and buying something else...Maybe just hanging up metal for for good!
Not really of course! I love metal work, But I currently hate my lathe and may put it up for sale soon if it doesn't decide to stop being so pissy!
Anywho....on a less negative note; I made a bunch of aluminum chips working on a tool to cut down .223 brass, that was relaxing and made me happy.
