- Feb 17, 2013
- 4,406
Good job on the X tram! But please elaborate on "front to back." Or better yet, what Y distance is involved in the .003" height difference? And is it high at the front or at the back?Since I don't think too many people are watching this thread, I'll pose this to you, royesse.
I trammed the head. Have it within .0005" from side to side, but there is .003" difference from front to back... that's quiet a bit! Is that to be expected?
As I'd mentioned in an earlier post, the only way to correct front-to-back tram is to dismount the column and either scrape or shim the mating surfaces.I see no way to correct that.
Also, holy weak column. Shocking amount of flex.
But then, you also noted that the column itself is relatively flexible front-to-back. What to do? Maybe look in on the Yahoo group or search here for mini-mill column stiffening methods. There are a couple tricks you can try. Or else just be sure to always take a final "spring" pass with a good, sharp end mill.
