- Oct 21, 2017
- 504
What would you use to cut into the brick?
I use an angle grinder with a Diamond blade
An angle grinder would work but it would probably be better using a dremmel so that you have much more control. Be sure to wear a filter mask of some sort so you DO NOT breath in the dust.
A Dremel will give you more control only if you are unable to use an angle grinder correctly ;-)
I would equate using an angle grinder as using a sledge hammer to drive in a brad nail.
Then you shouldn't use an angle grinder, you know your limits.
To everyone else I would still firmly recommend it as in competent hands an angle grinder with a diamond disk gives very fine control of material removal in brick, ceramic and refractory ;-)
If I was doing this "repair" i would go directly to where that burn mark is and i would start shaving down the outter edge until you get to the element wire and you should be able to find the break. Then if possible and dependent on the working temps i would braze or high temp soldier that break closed or most likely add in a new "wire lead" to that spot or if thats not possible go back to removing more ceramic from around the element so you can make a mechanical connection from the downstream side of break to a new "lead." As for fixing the ceramic i don't know of a way that you could! I suppose if it is a critical factor that trying some fireplace hightemp mortar might help but I think it would not stick to the ceramic element. I would be sure to round out any cuts you made into the brick ig possible to reduce the chance of stress fracturing when brought up to temp. Now im NOT Guaranteeing This will work but considering it's broken already and if you have more time then money it's certainly worth a try.If I were successful in finding the break how would I then fix the ceramic plate? Would I use some sort of firebrick cement?
braze or high temp soldier .
Nope, it's crimp connections only for heater elements in furnaces! ;-)
Unlike others I'm not guessing
