Depends somewhat if you are doing facing or shouldering, and a big part of the cost is the inserts. I would go with a 2.5" face mill as a good compromise that is wide enough surfacing as weel as shouldering and you should have enough Hp/RPM. I would suggest you look at the following which can bot shoulder and do surfacing:
HS6NP - Haas Sq Shoulder 6 -/+
This Haas Square Shoulder 6 Negative Positive shell mill provides high stability and allows larger depths of cut for face milling and shoulder milling applications. It has a 2-1/2" cutting diameter, and a 3/4" pilot bore, with a 90-degree cutting edge. The cutter body takes 5 triangular cutting...
www.haascnc.com
Toolpath Type: Face Milling, Shoulder Milling
90-degree cutting edge | D.O.C. max. .303"
• 90-degree shoulder mill
• Diameter sizes 2.5" 3.0", and 4.0"
• Double-sided, thicker insert for high stability at deeper cutting depths
• Inserts with 6 cutting edges
Materials:
K - Cast Iron
M - Stainless Steel
N – Aluminum*
P - Steel
I am using Convex Triangle Negative Positive, Grade HMP35 which is primarily for steel/SS but should work ok for aluminum, the HN25 inserts are for aluminum, could be used for light cuts in mild steel and should give a very clean cut.
HS6NP, Carbide Shell Mill Insert, Trigon Negative Positive, Grade HMP35 - Pack of 10
www.haascnc.com
HS6NP, Carbide Shell Mill Insert, Trigon Negative Positive, Grade HN25 - Pack of 10
www.haascnc.com
Insert Grades
HP30
HMP20
HN25
HMP35
HK25
If you are doing just surfacing then might consider the HOP, 2-1/2" Diameter Shell Mill, 3/4" Pilot Bore x 45° Lead Angle, 5 Inserts (Octagon), Positive Geometry, or similar with a positive rake insert. Also the Glacern FM45 face mill.
This Haas Octagon Positive shell mill is a great choice for general face milling applications. It has a 2-1/2" cutting diameter, and a 3/4" pilot bore, with a 45-degree cutting edge. The cutter body takes 5 octagon cutting inserts with positive/positive geometry. The screw clamping inserts have...
www.haascnc.com
Glacern Machine Tools manufacturers CNC Machine Vises, Precision Tool Holders, and Indexable Milling Cutters for vertical and horizontal cnc milling machines.
www.glacern.com
Haas HS6NP
