I'm trying to get a old GE Tri/clad motor going. I think all I need are the Start/run capacitors and a on/off switch. The motor is:
GE Tri/Clad
Model # 5KC145AL2003Y
115/230 volts
20.8/104 amps
1725 rpm
1.5hp
It appears to be wired for 230V and is missing the capacitors. It has 4 wires with clips, which I assume is where the capacitors go. Does anyone have any ideas on what capacitors I should be looking for? The 4 wires that have the clips on them are numbers 9,10,5 and no number on the 4th one. Any help you can give would be greatly appreciated.
GE Tri/Clad
115/230 volts
20.8/104 amps
1725 rpm
1.5hp
