Wow. Thanks for getting back to me. We must be the only two people that have these things. I have manuals for the 7, 10H, and the Clausing version of the 10H. I saw the machine under power and its smooth and quiet. Not realizing how top heavy it is we dropped it. Two of the control wheels were broken but seeing as all three were welded at some time in the past, I think this has happed before. I have been taking parts off, cleaning and replacing screws and pins. Getting the handles repaired. I even figured out what a loose piece of sheet metal was from (was spot welded to the "blind affair" at the top. Two pop rivets fixed that and I have a new piece of Teflon sheet to repair the blind.) But my main question is about the hydraulics. The motor and pumps are not secured to the base. When it fell there was a lot of oil all over the floor. When we got it up-righted we found a metal box about the size of a small shoebox inside tipped over. Its the same color (orange) as the inside of the base so I figured it belonged in there. Also looking into the base, on the left side, are two gray plastic tubes that come down from the top somewhere. They are both open at the bottom. So the question is, what are these for? What about the box? I'm using a VFD to power both motors. Actually found a youtube describing how to do it. One guy did tell me that its hard to prime the pump. I can send pictures of the stuff from the base I'm talking about if you can send me an email. I really appreciate you getting back to me. Oh, where are you? I'm in northern VA.
Chris
cvuxton@yahoo.com
