I understand backlash. I think that was during the first week of Machine Shop. I didn't mean for you to have to explain that part.
I was questioning if you thought there'd be some backlash with a ball screw.
I'm under no delusions that my machine will ever be a super amazing mill. I know it has limitations.
Most everything I do has a +/- .005 anyhow but if that gets better, it won't hurt my feelings. I've done .001 repeats on this machine so I know it's tighter than many hobby mills. I've already done a few upgrades and tightening to get it closer. The weakest link for accuracy is the quill on the mill head. It's not the best machining job out there and has a lot of limitations.
The DRO part is going to be done "Just because I can" and not to serve any important purpose. I might use it to hog out metal and then finish it manually. I could send the code to rough it out and sit back and watch.
I actually enjoy reinventing the wheel sometimes. That's why my current builds are a 3D printer, a 30X52 CNC machine, the Stepper mods to the combo and I have a car that never came with a 5speed transmission converted to a 5 speed using the original engine. (not as easy or hard as it sounds)
I will say this, though. The backlash is stupid loose and that's after tightening it up. Even if all I do is get that gone, I'd be happy.
