Help with ball screw calculation
Rockord's finest lead is .125" and that is on a 3/8" shaft. 10 tpi would be difficult to accomplish on a lathe lead screw as the balls would be tiny and not capable of carrying the load. I would suggest that the OP look at a larger lead, e.g., .20" or .25" and use appropriate gearing or software division to to achieve his goals.
My Tormach mill commands steps and assumes that the commands are received and executed properly. Backlash is controlled by mechanical means but still exists. It is on the order of .001" and there is software compensation available. A better option would be to have a separate and independent linear encoder system which controls motion. This would in theory limit backlash to the resolution of the linear scale resolution.
Tormach uses a term called "lost motion" which in addition to free play, also includes things like windup of the lead screw under load. Adjustments like increasing thrust bearing preload can actually increase the lost motion. Increasing cutting load will also increase lost motion. An example of this is the spring pass commonly used when turning on the lathe. A small diameter ball screw will be more prone to twisting due to load induced torque.
Looking around at Thomson ball screws, it looks like a 5/8 x .200 is available. On the page I was looking it seems the only housing available for the ball nut is square. I'd prefer a round housing but if that's all I get then I'd find a way to make it work.
The .200 pitch is ideal in this situation, for me, because I'm not going to try for anything extreme and I could easily set my stepper driver for half step and get .005 per step.
One of the things that blew my mind was a standard ball nut for the 5/8 x .200 was around $40. The heavy duty one was well over $400. It's just a longer ball nut with more balls inside.
Thinking about it, I have to check. I might actually have a 5/8 x .200 ball nut. If I do, it has a shaft that's way too short for this application so I'd just need a new shaft.
How did you eliminate the .030?
The connection from the leadscrew nut to the table had flex in it so I beefed it up.
If I added a second nut to tighten the threads I could remove more backlash but the main, number one, goal of this experience is to allow a faster Y-axis movement.
So, I checked out the ballscrew I had that I was almost sure was .200" pitch. Unfortunately it's a 14mm with a 5mm pitch. Very close. 15 turns come out to be a little over 3". Kind of sucks, too, because it had the heavy duty nut and alreay had the flange.
Project stays on hold til I get the ballscrew with a .200 pitch
I think I've settled on the ballscrew assembly I will get. In .200 pitch I could get .500, .625, .750
The .625 assembly is the least expensive. Will be $65 + shipping for what I need
I'll make a carrier for the nut. The one they offer is a little big and would need a lot of machining to get it to fit in the space I have.
Have you looked at hgr?
I see a lot of brand new ball screws there in many sizes.
