0 volts between v and w. That's with the drum switch in forward or reverse.If you're comfortable with it check for voltage between V and W with the drum switch on. Wear face protection and heavy gloves.
Please bare with me, i'm trying to wrap my head around this and I want to make sure I am understanding correctly. The Orange wire, motor lead and x2 wire need to be attached as shown in the included pictureI think I see the issue. The orange #3 wire is landed on #2 terminal. #3 terminal is located below #2 terminal. You can see the 3 marking on the bluish green insulator.
Okay change the leads, but made no difference. Contractor doesn’t pull in and there is no voltage between V and WYes, exactly. Always good to be sure.
Will do! Thanks for the replyDon't know if it's an issue but the leftmost finger looks bent more than the others- Check and make sure the
contact fingers are working normally and none of the "spiders" have come loose from the shaft
Otherwise the switch wiring looks fine- thank goodness Clausing used color coded wires
