Hi,
I am just getting started researching how one might turn or form a small "dome".
By dome I mean not a full radius half-dome (ball end, etc)
but a convex shape for which the radius would be MUCH larger than the piece being machined.
The convex dome need not be a specific dimension with an exact tolerance.
I am imagining a piece of 1" round stock on which the end is shaped a dome where the center/highest point is maybe 2.5mm / 0.1"
My first thought was to make some sort of jig to hold a cordless drill that I could use on the belt sander - where the jig bottom plate had a bolt and a slot (cut with router and large circle jig) such that I could "turn" the part on this large sweep/radius... but I am figuring there is some lathe option possibly ?
I have seen lathe ball turning attachments and the like - but those seem a) to be for small radii , and also complicated to make (for me).
what would you do ?
