[4]
HF Band saw fix and mod
[3]
[10] Like what you see?
jimbob
Active Member
Mar 31, 2012
30
Was about to buy a HF portable band saw when I saw one on Craig's List. Used for one project and came with extra blades for $60.00. Looked like new and ran ok.
Made a wall mount out of some scrap wood and then notice the huge wobble in the drive wheel.
After pulling the wheel I could see how off center it was drilled with no measuring needed.
So the solution, as I had no guarantee (used) was to bore it out the and sleeve it. Chucked up in the lathe I open it up a total of about .170. The aluminum was porous and full of holes plus every time when I tried to press in the sleeve it would score and bind. Finally did the heat and cold and it just dropped in.
I added an old Ryobi band saw table and now it's a nice little machine. It was actually fun figuring out how I could come up with a solution. There was a little more to the repair than listed but you will get the idea.
Hope this helps some with the same problem. I have watched several dozen utube videos and have seen drive wheel wobble and they seem to not notice. But mine was really bad.
markba633csi
Gold
Apr 30, 2015
3,440
I see what you did there, very clever; a super-compact vertical bandsaw.
Mark
[6]
[5] [7]
