Hobart 5614 Meat Saw:
2Hp 115v @28 amps/230v 14amps- Single Phase
98" Sawblade x 5/8" wide x .022 to .025" thick blade
They are reliable saws.
they are suitable size to break (split & quarter) sheep/goats and veal.
i have provided service and repair on them for more than 25 years.
most small meat shops and grocery stores have these saws working here in these parts.
they have Timken Tapered Roller Bearings on the upper and lower shaft assemblies
the repair parts are plentiful, but expensive unless you go aftermarket.
you could increase the size of the driven pulley, decrease the size of the drive pulley, or both to make the speed suitable for steel
the OEM speed is wonderful for woodworking, with a 3 or 4 TPI blade.
for metal i would suggest a 10TPI or 14TPI blade
