"Hobby use" is a bit broad Can you define your hobby work a bit.
Gunsmithing, Toy trains?
Plastic, steel, brass, aluminium
What tolerances do you aim for when machining
Members will chime in with good advice, but if you can clarify it a bit more the advice you get should be relevant
Cheers Phil
