- Sep 20, 2020
- 347
i was thinking of making a jig so that the sides are the same. i have a roller and bearing store down the road. i was thinking of maybe using an old bike steerer tube. but then i would have to bend the fork out ward. i think that making a custom one is a better idea like what you said. thank you very much.Your probably going to want to build a frame jig. You can go through a lot of tubing using the hit or miss method. You will have to come up with some sort of fork assembly, and steering head and bearings which may also be available on line. Kind of a right of passage for young folks to build something fast, loud, and dangerous. As you get older the HP, and dollar figures rise accordingly. Cheers, Mike
i am still deciding on bending or cut and weld. i think that cut and weld would be easier with sqaure tube. ill check the price. 5/8 tube and 1 inch tube with 1/8 wall is 2.06 per foot. i will use tube and cut and weld. it seems to be better than pipe at almost everything.Thank you very much.Peyton,
That should be fun as a project and to ride!
When I built a go-kart for the kids, I used square steel tube for the frame. As the corners are a little easier to cut and weld, and you have flat faces to bolt things to. I know bikes all use round tube.
Is the frame going to be bent tube, or cut and welded?
If using round tube and welded joints, a coping cutter would be of benefit.
https://www.instructables.com/How-to-Miter-Cope-a-Round-Tube-by-Hand/
https://www.hobby-machinist.com/threads/hole-sawing-pipe.67577/#post-564989
https://www.hobby-machinist.com/thr...d-you-do-in-your-shop-today.14637/post-253337
Have fun and be safe!
-brino
