- Apr 13, 2014
- 17
OK, I have cut 1/2" threads on a bunch of rods with my rigid pipe threader. Evidently something either moved or has wear because after threading them they are not quite right and the nut goes on very hard. I need to recut them. I can't run them through the rigid machine because there is a bent handle on the rod now. The question is, how can I recut the threads a little to clean them up? I have tried a die set with some success but it doesn't always work. Is there a special tool that will do this well? I must add that the threads are 6" deep. I have 200 of these to fix.
Thanks for any help.
