[4]
[How do I?] How do I remove this?
[3]
[10] Like what you see?
vin421
H-M Supporter - Silver Member
Mar 4, 2018
34
Likes
16
#1
Pictured is an ER11 collet tool holder on a 600w spindle motor with an 8mm shaft. (I think I am using the terms correctly) I want to remove the tool holder. I have removed the set screws and tried everything with the maximum force I feel I can use without damaging the motor. This seems like it should be an easy task but there must be something I don't know as far as how this is mounted.
4ssss
Brass
Apr 25, 2017
515
Likes
289
#2
Try heating it. It should expand. Or try a bearing puller, if it has a thru hole.
Tozguy
Feb 15, 2013
1,760
Likes
1,142
#3
What about using an ER collet to hold a short bolt as large as it will hold. Then use a pneumatic impact nut driver to unscrew it or loosen it from the shaft. Maybe squirt some penetrating oil in the set screw holes a few minutes prior to doing this. Not familiar with your problem, good luck anyways.
juiceclone
Active Member
Oct 24, 2014
201
Likes
117
#4
yes .. as above, probably threaded on. note which way the motor runs, to be sure you're removing in the right rotation. U can put a well fitting wrench on that flat on the fitting, and smack the wrench in the correct direction with a small pall peen hammer. smaller hammer moves faster and shaft has less time to spin, u may break it loose.
juiceclone
Active Member
Oct 24, 2014
201
Likes
117
#5
vin421
Mar 4, 2018
34
Likes
16
#6
Are you talking about heating it with a torch? I tried a hot air gun but no luck.
vin421
Mar 4, 2018
34
Likes
16
#7
It is made so that you can reverse the wires to the power supply and the motor will reverse direction. I didn't think it was threaded on, but it might be. There is now way to tell, as far as I can see, if it is threaded, and with way the threads are aligned if it actually is threaded.
vin421
Mar 4, 2018
34
Likes
16
#8
I like that idea. The penetrating oil will help whether threaded or not. I wish I knew if it was threaded and which way.
Tozguy
Feb 15, 2013
1,760
Likes
1,142
#9
The ER nut is threaded RH and is designed to tighten when turning. I would be surprised if the chuck is threaded on LH for that reason. Logically it should be a RH thread if there is a thread.
Ray C
Platinum
Staff member
Nov 16, 2012
5,215
Likes
1,443
#10
Is it threaded on the shaft perhaps? That would explain a lot...
If it's not threaded and if there's a hole in the end, try making some kind of a gear puller.
Ray
vin421
Mar 4, 2018
34
Likes
16
#11
Yes, but the ER nut is not the piece I am trying to remove. I am trying to remove the piece the ER threads on to.
vin421
Mar 4, 2018
34
Likes
16
#12
Ray
Yep that's where I am at now. The first one I made gave it up so now I'm building a new one....stronger!
I may just take it to a machine shop.
Tozguy
Feb 15, 2013
1,760
Likes
1,142
#13
What I meant to say is that the same forces apply to the ER chuck mount as do to the ER nut. So if we are trying to determine whether the chuck mount would be threaded RH or LH, my guess is RH, same as the ER nut and same as most (if not all) spindle threads.
kd4gij
Feb 7, 2011
4,672
Likes
1,846
#14
Looking down the hole the set screw came out. What do you see?
vin421
Mar 4, 2018
34
Likes
16
#15
I see just smooth metal. No threads. This axle is not threaded. It's just VERY, VERY tight.
kd4gij
Feb 7, 2011
4,672
Likes
1,846
#16
I would make something like this.
vin421
Mar 4, 2018
34
Likes
16
#17
Yes. I am in the process of making something like that. Hopefully it will work. If not, I may buy this item. What is the exact name for this and how much does it cost?
kd4gij
Feb 7, 2011
4,672
Likes
1,846
#18
It is called a bearing separator. On this side of the pond they start at around 40.00 For a set.
Tozguy
Feb 15, 2013
1,760
Likes
1,142
#19
What if you looked up the specs on your motor to see if it identifies the output shaft profile?
PS After looking up some info I expect that you have a straight shaft (not threaded). It might be a shrink type fit if provision is made for when the holder heats up in use, it will not get sloppy on the motor shaft. I would think that you need to use that puller as shown above and heating the chuck body already mentioned would help.
MozamPete
Jun 26, 2014
583
Likes
1,085
#20
What about making up an approximately ER collet shaped slug with a 8mm threaded hole down the middle. Put it in and tighten the ER collet retaining nut, then just wind in a long 8mm bolt to act like a bearing puller (I'm assuming you can see the end of the motor shaft through the collet holder).
Tozguy
Feb 15, 2013
1,760
Likes
1,142
#21
Good idea Pete. Maybe the slug should replace the collet instead of held in it, the max of ER11 collets is only .3125'' or thereabouts.
Silverbullet
Gold
May 4, 2015
3,419
Likes
1,673
#22
Maybe it's got a screw in the end of the shaft like a drill chuck???
vin421
Mar 4, 2018
34
Likes
16
#23
Thanks for all the ideas guys. Some very good ones!
I built a puller. I used a 5/16 bolt (just under 8mm) to push out the 8mm shaft. (Unthreaded, no screw in the end.) I twisted the bolt off and never budged the shaft. My next effort will be rebuilding the puller, cooling the collet holder (if that is the correct name) and shaft with dry ice, then heating the holder with a torch and try the puller.
What would it take to cut this damn thing off? It looks like very hard steel!
The other option is ...buying another motor without the collet holder, they cost less than $50, but that would be admitting defeat.
vin421
Mar 4, 2018
34
Likes
16
#24
Yes I can see the end of the shaft. Good idea, a 5/16 nut will fit in the holder. The collet nut will screw on. Then I can just screw a 5/16 bolt straight down onto the shaft. A hell of a lot easier than rebuilding my puller. Problem is, I already twisted off a 5/16 bolt. Do they make extra hard bolts for certain purposes?
Z2V
H-M Platinum Supporter ($50)
May 10, 2017
684
Likes
633
#25
I’ll just throw this in. If you have already broken a bolt if you go back with another try giving it tension then a few shots with a dead blow hammer. Then add a small amount more tension, then another few shots with the hammer. Repeat, repeat
vin421
Mar 4, 2018
34
Likes
16
#26
I like it!
Z2V
May 10, 2017
684
Likes
633
#27
“ Edit” , Hit the head of the bolt
Tozguy
Feb 15, 2013
1,760
Likes
1,142
#29
No don't give up
Yes to a new hi grade bolt and nut, 5/16 fine thread
Yes to putting tension on the bolt then hammer till tension drops (not a dead blow, it needs to vibrate lots)
Yes to heating it up while there is tension on the bolt
We will get this sucker
Hooray for our side!
vin421
Mar 4, 2018
34
Likes
16
#30
No don't give up
Hell yea we'll get this sucker!
[6]
[5] [7]
