I wring them to the vise jaws by wetting them with a little WD-40. After that snugging the jaws, seat the piece with a deadblow, then fully tighten and they aren't going anywhere.
I never had trouble with the parallels moving around while machining, it is the reseating process between parts that eats time.
I have tried::
a) grease
b) oil
c) WD-40
and d) rubber bands
None of these saves you from having to clean out the chips that can get under/behind the parallels.
The best I have found is keeping a clean rag within arms reach.
Dead blow and a quality vise. Kurt. That is if you are talking about moving while machining. If setting up too many ways to fix that issue. Take your favorite that works for you.
