- Jul 21, 2015
- 566
Run away from that junk.
A Bridgeport has backlash adjustments on both axis nuts.
If your just moving the table the backlash amount it may be a simple fix.
But if the X axis rotates 180 degrees that should only be .100 in table slack movement.
.050 on Y with 90 degree slack in the handle.
$1500.00 is cheap for mill in my area.
That is the purpose of this post, to try and get an idea about a price range and complexity of needed repair. I have been watching Craigslist for a little more than a year, and where I found this. $2500 seems to be about the lowest a decent mill of any size other than a mini.I've gotten to a point in my life where I don't buy things that aren't gtg when I get them home, I used to buy fix-r-up equipment, sometimes it was a quick and easy fix, other times I took a bath with my time and money.
Maybe look what it takes to fix similar problems on a like model Bridgeport to get a possible idea of time and money to fix. Have you looked at your local Craigs List to see what may be available?
I'm about an hour and a half North West of Fort Pierce now, but Fort Pierce is where I grew up.Sounds like some one robbed the gibs out the table/saddle to cause all of that side to side movement. As others have said, "better pass on this one!"
You live near where one of my kids was living last year at Ft Pierce.
Not around here!you can get a bridgeport for that
