Yes, your observation is correct. I did use a 1/2" endmill. That facing mill was homemade by someone, welding a 1/2" shank to a cutter that was cannibalized. I've never quite trusted it since overlapping cuts sometimes sometimes seem to leave a ridge. I may have to do a better job of making sure all is in alignment on the mill. I have flycutters, but never used since I do not know how to grind the hi-speed steel tool bit for use. I tried, but the cutting result was not so good. I can grind my own on the lathe, and they work OK there.
I will use the facing mill next time, and make sure the mill is dead nuts trammed.
