Someone threw away a somewhat rusty propane tank that I'd like to open and make a propane forge with. It has a screw sort of top, but I'm wondering if unscrew it there will be pressure. I'm thinking to take it out in the field and from 50meters blow a hole in it with my 9mm. Not sure if it will explode. Follow-on question is, is the next step to fill tank with water to ensure all LPG is out then safe to start cutting? I have some fire wool (forget the name of it) to line inside of the tank. Much thanks. I always do safety check on this forum before doing something questionable.
