- Apr 23, 2018
- 6,570
I am not sure of how to pull this shaft. The thread is about 10 x 1.0 mm, very fine. I tried using a piece of tubing as a rigid sleeve and using the special nut to press the casting off, but the shaft is too firmly held and the nut too hard to hold with a pin spanner for that approach. What I need to do is cylinder grind the shaft to remove excess taper, and enlarge the relief that doesn't line up with the locking screw very well. This is a non-negotiable modification at this point, since the bug/defect is affecting the mechanism's performance. I'd gladly turn a new shaft, but if I can't get the old one out first, I'm SOL. Any ideas?
