Madmodifier
To me the geometry of the shaper is still a bit of a mystery.
The ram can pull down into the cut or be pushed up depending on tool geometry and material.
Thats a consideration for any operation you'll do on that machine.
I spent some time searching through Machine Tool Reconditioning and came up with a oil clearance of 0.0005" to 0.00125" for the ram
ways. This would be for a machine with properly scraped surfaces for oil retention, not a well worn machine, and since I couldn't find
any reference to shapers I determined the clearance from other machines with sliding ways listed in the book.
Perhaps Richard could confirm or correct this figure.
It's easy to check your clearance with a feeler gauge inserted into the ways front and back of the machine and with the ram in at least
three positions. If you cant slip a 0.0015" gauge in there it's really good.
The vertical column ways of my machine, as best I could measure, leaned back 0.0007"/ft.
This would give rise to the outside of the table but when checking the carriage I found variations of as much as 0.004" that was due to
original scraping and not wear. this would prevent perfect adjustment of the gibs and could allow the table to sag and move under pressure.
Further, the vice wasn't true and it's surfaces weren't flat.
I guess what I'm trying to say is that the machine may not have come from the factory correctly produced and with wear and time you will
have to live with some problems or rebuild it.
If you're not going to rebuild it then check the vice for problems that you can correct and cut the table true with a load attached.
One thing you should check, there are four pieces of felt in the bottom ram ways that should be changed. They help keep the ram lubricated
and pull trash out of the bottom way. From memory they are 1/4" thick and 3/8" Dia.
The tapered link pins below the ram push out to the right as viewed from the front of the machine. I no longer remember if there
is a set screw but can check my pictures.
A problem with changing those is the shim pack that sets the clearance of the ram ways might be ruined and you will have to cut
new ones.
You've got a really nice machine there.
