- Feb 21, 2022
- 771
Anything is better than the balls rubbing together. I make linear slides and use polypropylene, it's cheap, durable and the sheet thickness is within a tolerance I can work around. I pitch the balls at 1.5 diameter but would go bigger if I had the room. Piercing the holes gives the cleanest result, I have +0.2mm on diameter, again I would go bigger if I could.Quick question. Would HDPE do,because I have some on hand?
