- Jan 3, 2015
- 400
I have a Jacobs-style chuck on an R8 arbor for my Grizzly G0704 that is doing something I simply don't understand. The centerline of the holes seems wrong but the bit doesn't seem to wobble as much as it should.
I've seen this issue before but dismissed it as an error on my part, but yesterday I saw it again. The other times, I readjusted the mill to put the part on the centerline and assumed I had gotten the edge zeroed incorrectly.
I'm making some part for my flame eater engine project and my plan was to cut the outline of some parts and then go back and drill holes in specific locations. This way the holes will be on the same coordinate system as the outline of the parts and be exactly in the right place.
Last week, while making the flywheel, I made a holder for a #2 center drill that fits a 1/4" collet and used it to start the holes.
Then I switched from the quarter inch collet to the drill bit for the big holes at the top, with a 9/32 bit in my chuck and it was visibly off center. Even my wife commented on it and she doesn't have the eye for small differences I've developed. If it's visible from a few feet away without a magnifier, it's way off.
I chose the 9/32 bit almost blindly; it's to clear a 1/4" shaft and allow my 3/8" OD bearings a shelf to sit on. So as an experiment, I tried switching to a 5/16 bit in my 5/16 collet and it as visually right on the center. I drilled 5/16 holes. The other four holes (at the bottom) were a size I didn't have a collet for, so I went back to the drill chuck and visually centered the drill bits. It was about .015 off.
So how can a drill bit in a chuck on an R8 arbor not be on the centerline like a part if a collet in the same spindle? Shouldn't it wobble that .015 or nearly .030 total? I don't see how it can be as wrong as it seems to be.
