- Feb 8, 2014
- 11,153
With your indicator setup it looks like you have a lot of overhanging mass all supported on a 1/4 inch pin. That could affect your reading. Not saying it is a factor, but that it could be.
Try checking with your quill both retracted and at full extension and see if the readings are different. That might be a good indication of column tram. A good 12'' square and an indicator might be useful for checking the column tram. Maybe check the square for squareness by laying it on the table and indicate the X & Y, that assumes that your tabel runs square. Not sure how else you could check the square of the square.
