- Aug 3, 2015
- 154
Yesterday, my first machining project went nightmare on me.
As I was assembling the new parts with the reusable parts and the refurbished parts.....
I discovered one of the refurbished parts was actually faulty. I should have tried to position the shaft properly when sizing things up last week.
There was a worn down section in the 1.25" shaft (the worn area measured 1.182" and appeared to have properly machined shoulders).
So I cleaned the worn area smooth and chamfered the shoulders. Then found a piece of scrap that I curled and fitted it into the grove. I TIG welded the scrap into the grove while still in the lathe.
After it cooled a bit, I reduced the diameter of the filler and the scrap so that the bearing and collar would slide over and lock in place.
An extra 3 hours when I thought I'd be done in under one.
