I f one does not care about machine alignment or cutting unintended tapers, that would be a good idea.
True 'dat!If God had intended casters to be applied to a lathe, he (or she) would have created them as such!
I have those on my 1400# mill. The adjusters are a PITA to get to and use (you need to jack up the machine to get the weight off the pad to adjust it), the wheels are too small to roll well for the weight and the pads are too soft for precision leveling of a lathe as they compress over time. Last time I moved my mill I used a toe jack to lift it and put the caster/feet on machine skates. Took 1/10 the time.I don't know, John. With the leveling casters you find today, wheels and a level lathe are not incompatible. A Carrymaster SLC-600 caster will support 600# per caster and raise the lathe up 4". It will allow for easy mobility if needed but will also provide a solid base that is easily leveled. If the lathe just needs to be raised then the steel bases that the guys showed is ideal. If the lathe must be mobile from time to time then I would consider Carrymaster casters myself.
