Terry,
If there is enough clearance, try pulling a length of shrink tubing over the unthreaded part of the drawbar and shrink it. Probably won't totally stop it but at least it won't be the sharp metal on metal sound.
Robert D.
Interesting thought, Robert, and not a bad idea. The old drawbar had room for some heat shrink along part of the shank, but the new one does not.
I believe you are overlooking something that has not been mentioned yet. At least I didn't see it in this thread yet. Check the Vibration Dampners on the motor mount between the motor and mount. There is one on each bolt. If these are bad it will cause your problem. Make no mistake, they are there for a reason, as the vibration becomes greater as the speed is increased.
"Billy G"
Interesting point, Bill, thanks for bringing it up. Since the motor runs at a constant speed, wouldn't the vibration be the same at all speeds if it were being caused by the motor?
The rubber vibration dampers on mine were hard and crusty and breaking apart when I got my mill so I ended up making new ones that are spacers made from Delrin with two pieces of old inner tube on each side. Not the best, but they seem to work, I don't get any vibration on my machine from the motor, or at least not that I can tell.
My machine only makes noise when I am cutting, and it is worse at higher speeds. It does not make noise when drilling, only when applying side pressure. It has a metallic chattering sound that I find hard to describe, but it sounds to me like the drawbar is hitting on the inside of the spindle. There was a thought that it might be one of the bearings, but the spindle feels fine when I turn it by hand with the belt removed. When I got a different drawbar for it I thought that the problem might go away. It is less of a problem now, but it does still occur, so I am leaning toward rebuilding the head on mine, putting in new bearings and having it over with.
I guess I will need to attack my machine one little problem at a time, and will probably start with purchasing some proper motor mount bushings or grommets, whatever their proper name is. The bearings for the intermediate pulley were both replaced when I bought the mill, as one of them was bad then, so I guess the next step would be to rebuild the head.
In Jimmy's case I thought it best to 'divide and conquer' and narrow down the source of the problem to see when it occurs. If you take a part of the machine out of the picture and the noise still occurs without change, then that removed part has nothing to do with it, or so one would think.
