Being on a museum budget,as toolmaker in Wmsbg.,I have used a few of those sets.
A problem with them is they may or may not be fully sharp. Some are,some are not.
The Tin coating is so thin you can just about see through it,so I wouldn't be concerned if it is there or not.
Those Chinese HSS endmills are harder than American made ones,and will break easier. But,they also will mill some metals that others will not. It's a trade off. ALL Chinese HSS I have used(quite a bit) is harder than USA stuff. I don't have a problem with that. I don't know if they'll hold up as well as GOOD,OLD,VINTAGE USA HSS,but since I've not been involved in production work,this has not been a factor for me.
I would say go ahead and buy them,but not from HF. They get the cheapest of the cheap,and if the cutters have a chance of being not fully sharpened,I'd bet the HF ones are at the top of the poo poo list.
Since I have a tool & cutter grinder,I haven't been as concerned as others might be about sharpness. I'd buy from Little Machine Shop,where you at least have some customer service. Except the shipping back and forth will probably equal the cost of those end mills.
The bottom line,as is most usual,is you're going to get what you pay for. But GOOD end mills cost so much that 2 of them would equal the cost of that set. If you're a hobby machinist,I'd say go ahead and try a set. I have been able to do good work with MOST of mine(though I CAN resharpen them,as said).
