I've made a number of things on my 1340GT since getting it up and running last week. I bought a BX27 belt and flipped the pulleys and am running the two large pulleys with Mark's VFD setup. I read in the owner's manual to not use gravity on the motor to set the belt tension so I loosened it a bit a few days ago. After getting the tach set up I was playing with the gears and running the speed pot to see how fast it would go. When I started it in high I got a high squeal and found it to be the belt so I went ahead and tightened it using the weight of the motor. Well, today I found I had a lot of vibration. So much so the chip pan would shake. I used the speed pot to work around the vibration. Since that was a new problem, I loosened the belt and all vibration is now gone. Zero. The belt is quite loose. I'd never have thought about running it that loose but it works well.
Something to think about if you guys get vibration.
