Is there a particular brand of belts that you find to be of better quality?Use of linked belts does help in some cases, but technically they are not bidirectional per the manufactures recommendation. They were originally designed as temporary belts. Harmonics and vibration nodes can be more of a problem with VFDs because there is always some harmonic frequency point for every system, one reason why VFDs are designed with skip frequency bands so one can bypasses those frequency ranges. The 1340GT always seemed to be a bit more sustainable to some excitation frequency, partly because it is "relatively" light weight wise, sits on a tall cabinet, and has a high center of gravity. Small weight imbalances in the chuck can also cause problems. Belt tension is just one factor in the equation, along with better quality belts (that are more uniform in dimensions and less likely to take a set) that individuals need to evaluated. Tighter is not always better, but I also reacall a 1440GT owner complaining the spindle speed was dropping when he was cutting, and his belts were too loose. So the porridge needs to be just right, not too hot and not too cold.
Thanks
Howardd
