Indexable insert for S.S. and Titanium?
JimDawson
Global Moderator
Staff member
H-M Lifetime Diamond Member
Feb 8, 2014
9,762
I would start here https://www.amazon.com/AccusizeTool...762&s=gateway&sprefix=accusize,aps,194&sr=8-6
I have found the Accusize insert holders to be a pretty good value. I use them both on my manual and CNC lathes. The only problem I have had is the 3/4 shank parting tool wasn't quite up to the task on the CNC lathe.
For inserts I have been buying from Shars. https://www.shars.com/products/indexable-cutting/indexable-inserts
I can't tell any difference in those vs. the high prices name brand names.
mksj
Jun 12, 2014
2,807
The 3/8" shank holder is limiting, also need rigidity. You might look at the Shar's holder, assume you want an external right hand.
Depending on the thread pitch, I would recommend a 16ER AG60 (A60 is for finer pitch), haven't tried the Shar's inserts but tried Cobra brand on a different threading holder and they broke very easily. On Lay down inserts I have been using Carmex (Iscar) and I have done quite a few threads with the same insert and still on the same cutting tip. I also have some Mitsubishi MMT VP15TF-16ER-AG60 inserts that I haven't used yet, they supposedly give cleaner cuts with less vibration. Might work better on SS and Titanium, you will need to take sufficient cut depth per pass due to work hardening of the metal. I prefer the lay down type inserts for threading, they seem to be more durable and I get very clean threading finish.
MalR
Jan 2, 2018
39
If you were machining lots of parts you’d use different grades of inserts for stainless and titanium but for small quantities most cheap coated inserts should do the job. And you can use these on other jobs in the future. There’s a HUGE range of shapes and grades to choose from. If you want to get your head around the world of inserts try this document over on the Bridgeport Mill group: https://groups.io/g/BridgeportMill/...ades/DS30 - Inserts for indexable tooling.pdf (not sure if you need to be a member).
For threading, be aware that you might need left or right hand inserts (and matching holders) depending on whether you are OD or ID threading and whether you are cutting to a left or right shoulder.
Go for the largest holder your machine will take as this maximises the stiffness. And buy a holder that takes cheap and easily obtainable inserts rather than tie yourself to one supplier. The big name suppliers all produce excellent inserts that in my experience last longer than the the cheap no-brands, but for home workshop use this difference is minor compared with the cost.
Could I put in a plea to treat inserts as *recyclable* rather than disposable: save your worn out tips and mail them to a carbide recycler - tungsten is quite a rare metal and it’s a shame to send it to landfill!
Mal
AKA The Felsted Skiver
mikey
Global Moderator
Staff member
Dec 20, 2012
7,778
If you have a lot of stainless and Ti to do then it will pay to buy good inserts and a tool holder that beds the insert precisely. I would suggest looking at Carmex tools and their BLU inserts in particular. I think an AG60 laydown insert will work well, at least in my experience. A Carmex tool holder is $20.00 more than a Shars holder and if I were going to do a lot of threading then I would go for a known good tool holder and inserts.
GunsOfNavarone
H-M Supporter - Gold Member
Jun 26, 2018
1,134
I apologize I have nothing valuable to add, but I am in the process of doing internal and external threading in Ti. I have read RT9010 is the material insert I (we?) Should be using. They are available on ebay like everything else. WE seems to be another (easier) animal to deal with. Can anyone she'd some like on insert materials?
mksj
Jun 12, 2014
2,807
I have been using the Carmex AG60 inserts in a wide range of materials and they have held up very well, the coating material varies but it is more the cutter profile that will make a difference. I also have some of the Mitsubishi VP15TF AG60 inserts that are specific for difficult to machine alloys, but have not used them yet (I am still using the same Carmex insert after about 100+ threads). I purchased the Mitsubishi from the dealer below which states they are authentic, but you can also try Carbide Depot. I use to break threading inserts all the time with other types of holders, switching to lay down type with Carmex inserts I have yet to break an insert even with deep threading. My threading holders are also from Carmex, which is a rebranding of Iscar.
GunsOfNavarone
Jun 26, 2018
1,134
Hey Folks,
Can I get some recommendations for an indexable insert I can use to thread some 7/16-40 pieces in 303 and Gr. 5 Ti? I've got quite a few to do, and the job is big enough that it's time to invest in some indexable tooling.
I'll need inserts and a 3/8" shank holder.
Smoke.
I started with grade 5 and very quickly decided I should be working with grade 2. Is there a reason that you must use (I think that is 6AL4V) grade 5?
stuarth44
Jan 22, 2020
114
Hey Folks,
Smoke.
I,m a builder of metal yachts, what, please what is an indexing lathe tool( dont larf too loudly) and can someone point me to a straight hss holder American style
GunsOfNavarone
Jun 26, 2018
1,134
Good Lord! Can you even knick Titanium with HSS?? Hopefully I never have to try!
stuarth44
Jan 22, 2020
114
not what I meant at all, i have some threads to do 11/8 inch u.n.c, prefer hss carbides are moonbeams too easily stuffed
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,771
Yes. I mean I've drilled Ti 6-4 with HSS drills, not fun at all & I prefer not to use HSS.
macardoso
H-M Supporter - Silver Member
Mar 26, 2018
1,435
I have done fine finishing in 316 SS using CCGX and CCGT ground inserts for non-ferrous alloys. I don't think it is the ideal application for the insert, and the tool life is subpar, but it leaves a wonderful finish and allows me to take finish passes as small as .0005". Any -GX or -GT insert will have a polished top and a razor sharp ground edge.
PS: These inserts are amazing for aluminum and brass if you haven't tried them.
stuarth44
Jan 22, 2020
114
abom79 has vid on CNMG inserts, Naverone will look at your att. ;later
bakrch
Nov 24, 2018
211
Yep, even on 55-58 HRC 440C stainless those inserts will take very light finish cuts like that. I hardly ever admit that, because it is not documented to work for this application, but I've been doing it successfully for years.
I will only use ground periphery for finishing, and it drives insert salesmen crazy because their engineers tell them I am wrong.
eh, maybe ... but it works well enough to give me confidence to repeat it over and over again.
AdBlock Detected
I've Disabled AdBlock
