- Nov 28, 2016
- 2,406
Mark, Bear, I think these chucks are very cool. However, when I first heard of them from Mark, I took a long look at them and decided for myself, they were not worth the cost. I do not own one so my comments are coming from ignorance but it seems to me that a 3 jaw, when used for a first op, would not need adjusting. For a second op, a 4 jaw is faster and should hold more solidly given that the part is held by tension of the screws for each jaw vs a scroll. I can see how putting the part in the chuck would be faster with a scroll but for the rest of it I just don't see the advantage, especially in light of how much they cost.
I can see one if you are trying to avoid having to switch out chucks or if you are dialing the chuck in to make a production run on some nominal stock of the same size but in a hobby shop, these are non-issues.
Again, I am speaking from ignorance. Is
my logic off?
No offense, but actually, yes... first, you are correct that for a first op, a standard 3 jaw normally would not need indicating.
For a second op, from my experience, it is still faster than a 4 jaw independant unless you also used the 4 jaw for the first op... in which case the 4 jaw would already be very close to being centered anyway...
As far as holding the part securely, you can apply as much holding force with the adjustable jaws as you can with the scroll... or with the independant jaws on a 4 jaw...
Normally, by the time I have a part indicated, the jaws are tighter than what I put on them with the scroll. I have not had any issues whatsoever with the work coming loose, moving, etc.
I did wonder the same thing when I first bought the lathe... but I've since found it to be a non-issue.
Both of my combination chucks were with the lathe when I bought it... along with a 12" 4 jaw. I won't form an opinion on whether the cost is worth having one... that is up to the individual user. I will say that if something happens to this Rohm chuck, I will be looking to replace it with another combination chuck.
My other combo chuck, the 9 inch Union, is worn so badly that the scroll pinions tend to bind up... it is useable, but not easily, so I don't use it at all. It is currently a dust collector.
-Bear
