That's a good point as it seems that if the torx was hard enough to cut the form tool it should be hard enough to broach. I suppose he was mainly trying to demonstrate his method of achieving radial cutting relief on various types of form cutters.Interesting, but I don't understand one thing. He used a torx bit to machine a tool to make a torx bit for the rotary broach. Couldn't he just use original torx bit directly in the broach? Obviously it depends on the hardness of bit and material to be broached.
Mike
He probably made the cutter slightly oversize so there's clearance for the torx bit.Interesting, but I don't understand one thing. He used a torx bit to machine a tool to make a torx bit for the rotary broach. Couldn't he just use original torx bit directly in the broach? Obviously it depends on the hardness of bit and material to be broached.
Mike
Same. In case you (anyone) don't know, you can turn on closed captions in youtube and change the settings to auto-translate what he's saying.That is one of my favorite channels. His inventiveness is off the chart.
I've noticed he does a lot of hardening with water as a quench medium.Same. In case you (anyone) don't know, you can turn on closed captions in youtube and change the settings to auto-translate what he's saying.
Did you see today's video?
Apparently in soviet Russia, rebar is made of tool steel.
My wife is eastern European. I've been slowly learning Russian for a couple years now (I learn languages about as fast as I machine, it appears.)Same. In case you (anyone) don't know, you can turn on closed captions in youtube and change the settings to auto-translate what he's saying.
