- Aug 6, 2015
- 3,896
Searching got me to look at those first and quickly ran away from them when I saw the price... US$5,800.00 yikes. The least expensive that I saw are no-names and in the US$3K range... Grizzly has a 10" for US$1,600.00.I have a Black & Decker abrasive saw just like yours. In the scheme of things it's the least used saw in the shop. The main reasons are as you state, noisy, less accurate and less powerful. Add to that the mess it makes and it's far from my favorite.
The latest of the collection is a 14" Baileigh cold saw. It has variable speed from 21 rpm to 124 rpm. It's quicker than any of the other saws and highly accurate at +/- .001". However, it does require coolant and makes piles of swarf when cutting solid stock. Blades run about $150.00 to $200.00 each and different blades are required for different types and sizes of materials. I currently have 5 blades which should cover the range of materials I cut.
I happened on the one I bought at an excellent price from a used equipment dealer. It needed a fair amount of work but was well worth it in the end. I doubt I would have even considered buying one new in that they usually run between $6,000.00 and $12,000.00 depending on the brand and features you select. I would never get enough use out of it to justify that price.
Everything in the garage is a hobby for me... can't see myself spending that much on one. Even as cool as they are...
