Art - we went through this in tech a bit. If there is a problem we would certainly take care of it, but what was being described was well within tolerance. The nod being out .0025" over 8" is within spec. But you said ridges are happening in the cut. I have not seen any pics of the ridges or anything, all i've seen is the level bubble pics.
The last email about dimensions, you said that you had loosened the mounting bolts and the table was within .00025 So we thought all was good.
If there is a problem and something is out of spec, we will certainly take care of it. But the measurements that are being gone after are not going to cause the stepped ridges in the cutter of a 5/8" end mill if you are at .0025" out in tram over 8". Divide that up to the 5/8" cutter and its minimal.
And as far as scraping the machine in for $3200, I'd say a big no. Yes if they can perfect a machine and get things within .0001" all over, and you would want to pay for that, then sure. But to me thats kind of like buying a 1/2 ton truck and changing the motor, frame, axles, so it can handle 1 ton. If that description makes sense.
Like I said Friday, I am headed out of town for a week now and you were waiting on some things and would report back. Check that out more and see, but I would double check that tram. The .0025 dimension given is within spec, but it does not hurt to get it as close to .000000 as you can, that just takes some shimming or some adjustment. (be sure to check the X gibs first before shimming anything) The table and that level way difference does not have anything to do with the step over in a 5/8 cutter. It would be the same as putting something in an angle vise and tilting it, and taking a cut on the surface. Its still going to cut flat even though the vise is tilted up.
